which is the best for my application ?
Old Dec 19, 2008 | 10:29 AM
PONTIAC SLP's Avatar
Post which is the best for my application ?
Hi , my car with shoot +600RWHP , so i'm planning to purchase some stuff from RAM , Slave Cylinder and master Cylinder do you advice me with those ? or go with GM ? , well what clutch i should install ? LS7 or Ram i'm puzzled between those two so please guys don't say spec or anything as i said between LS7 or Ram
thanks, Mohammed.
Old Dec 19, 2008 | 10:51 AM
blue99fbody's Avatar
to much power for an ls7, why limit yourself to those two choices. im gonna try a monster level 3 or 5, how you getting to 600+ are you gonna be on a stock bottom still
Old Dec 19, 2008 | 10:56 AM
Benner's Avatar
No way the LS7 will hold out for long making that much power if you run it hard. I'd step up to something stronger than a ram.
Old Dec 19, 2008 | 11:34 AM
not stock bottom , rods and pistons installed with all ARP studs and bolts , so LS7 good choice ? or what
Old Dec 19, 2008 | 03:00 PM
Slowhawk's Avatar
LS1Tech Sponsor
LS7 =no.
Go with a Monster stage 3 and be done.
Old Dec 19, 2008 | 10:24 PM
BarneyMobile's Avatar
An LS7 clutch wont hold that kinda power. That clutch might slip the first time you lay into it with that kinda power.
Old Dec 20, 2008 | 07:18 AM
should i need to change the slave Cylinder and master Cylinder or not necessary ?
Old Dec 20, 2008 | 08:47 AM
Benner's Avatar
at the level your wanting i'd upgrade both
