regular 6 speed with big power
Old Dec 20, 2008 | 08:03 PM
Carlos_Garza's Avatar
Default regular 6 speed with big power
Hey guys, I'm building a 1999 camaro for the street and the drag strip. I don't know how much rwhp my car will end up making but I'm hoping I can use the regular 6 speed tranny. I'm installing AFR 225 heads, with an MS4 cam and a FAST 92/92 setup, among other moods. So my question is, how much rwhp can a stock 6 speed manual take?
Thanks a lot,
Old Dec 20, 2008 | 10:18 PM
thesource's Avatar
About 600-650 rwhp is pretty safe on a stock unit . Can they fail with less power ? Sure . Will they take more ? Maybe .
The key to making the transmission last longer is to have the clutch working properly and don't use one that hits too hard .
Old Dec 20, 2008 | 11:31 PM
I think I'll be around 450 rwhp and I will run the car with the stock suspension for a while, so I guess I'll be ok. I'm using a SPEC 3+; hopefully it will do the job...
Thanks for the tip,
Old Dec 21, 2008 | 09:45 AM
twitchtwice's Avatar
yeah, the t56 from what i hear is bullet proof for the most part. but it can still fail, but at 450 like what your at as long as you can drive it should be fine
Old Dec 21, 2008 | 11:23 AM
JDP's Avatar
JDP
i would worry about the stock 10 bolt over the tranny as the first to break
Old Dec 21, 2008 | 11:28 AM
thesource's Avatar
Thanks for the tip,
Tremec rates them around 450 but thats way low . I've seen stock units hold up behind 700 rwhp .
Old Dec 21, 2008 | 01:19 PM
yes, I know, that's the main reason I'm not doing any suspension work just yet... I plan on changing the rear around june next year...
Old Dec 22, 2008 | 08:47 PM
bad6as's Avatar
if your gonna be launching high and hooking hard get a torque arm relocation kit. my t56 was built back when the ls7 clutch started coming out and t56 rebuilds was six speeds inc. i for one never had an issue with mine. all the parts inside mine are replaced. expect the shafts and gears
Old Jan 3, 2009 | 07:43 PM
Thanks for the advice, I'll look in to it....
