Installing ls7... Question on slave/master cylinder
Old Dec 31, 2008 | 02:59 PM
DarkhorSe_SS's Avatar
Default Installing ls7... Question on slave/master cylinder
Has anyone bought the slave/master from AZ?? Called and got quotes from them which are cheaper and come with lifetime..
What are the results for those who have tried from AZ?
Thanks
Old Dec 31, 2008 | 03:31 PM
SLP4CamaroSS's Avatar
i work at az part time and i compared the GM slave and master with the az part. There the same thing so save your money go go buy the az part. theres a post on here saying the same thing if you dont believe me
Old Jan 2, 2009 | 09:12 AM
ghettocruiser's Avatar
Im running the AZ unit right now with my LS7 clutch. I got the one with the
"AP" part number in the casting. Seems to be working fine. I still have shifting issues... but I dont think its the slave. I also have a new GM slave that Ill put in the next time I upgrade my clutch. Hoping the LS7 holds out for awhile. Then Ill go with a TEX, and slap in the new slave along with the TICK master cylinder.
You should be fine with it it though.
J.
