Clutch suddenly will not disengage, changed master and slave, didnt work.
Odd problem
Has a spec clutch thats been in for about 10,000 miles with no problems. Stock original master/slave (car only has 30k on it)
Was driving the car, the car (2000 SS) was getting harder and harder to get into the gears then suddenly went to put it in gear and it wouldnt go into any gear at all.
Then after the car sat awhile clutch worked fine again for about a mile then would quit. Its random.
Shut the car off, put it in 1st and started it and the clutch wouldnt disengage at all. So I thought "crap" slave or master failed.
So I changed the slave/throwout, bled it, didnt fix it. Pulled clutch and found broken spring on clutch disc.
I had one of my guys pull the tranny and install the slave/master when I away on business and he didnt pull the clutch off and inspect. (because i had only told him to replace master/slave)
No, it has great pedal pressure (never changed, very solid) and doesnt disengage the clutch.
Which makes me think its pushing pressure properly to disengage the clutch.
My next move will be pull the tranny and inspect clutch/flywheel/pilot bearing and also push in clutch with slave hooked up with tranny out and see if it operates correctly.
