Not disingaging?
Old Jan 5, 2009 | 06:19 PM
therobman's Avatar
Default Not disingaging?
when im at a dead stop on a flat surface when i push the clutch down and put it in 1st gear is moves a little bit forward not a lunge the tinyest bit but noticable. i also did the test went to a flat surface with it in fist gear with the clutch to the floor and reved it all the way up it didint budge what could it be i have no problems with shifting downshifting or slammin the gears
Old Jan 6, 2009 | 12:23 PM
therobman's Avatar
anyone?????????????
Old Jan 25, 2009 | 10:13 PM
therobman's Avatar
someones gotta have some input
Old Jan 25, 2009 | 11:39 PM
MrElectric03's Avatar
Sounds like you need a shim behind your slave cylinder. This moves the slave cylinder away from the trans so that when you push the clutch the cylinder pushes on the pressure plate more. I had this problem with my centerforce and it was very annoying. I have alot of trouble shifting at high rpms but I didnt notice it until I did the h/c. Just today I ripped that POS centerforce out and installed a Textralia that doesnt need a shim...hands down the best clutch I have ever driven!
