rust on flywheel question..
Old Jan 8, 2009 | 01:52 PM
michaelxx16's Avatar
Default rust on flywheel question..
if there is some rust (surface rust from sitting on the car w/o the transmission on) on the flywheel, shouldnt it just burn off/come off the first few uses of the clutch when i put the transmission back on?
(stupid question i know lol but thanks in advance )
Old Jan 8, 2009 | 01:55 PM
bww3588's Avatar
just hit it with some brake clean and a scotch brite pad. before you put the clutch on, clean it good with brake clean and a soft towel.
Old Jan 8, 2009 | 01:58 PM
Trans Am Jam's Avatar
if ur doing that ^^ make sure u do nice even strokes =]
Old Jan 8, 2009 | 02:00 PM
bww3588's Avatar
circular motions usually work well, it has to be a non directional finish.
Old Jan 13, 2009 | 12:37 PM
is this fine to install the clutch on? (the flywheel has less than 3k miles on it yet it looks like this what i get for being lazy i guess..
the little spots you see are raised up, not down into the flywheel, ive been scrubbing in circular motions w/ the scotch brite pad and some brake cleaner to no avail.. looks alot better than when i started.
Old Jan 13, 2009 | 02:35 PM
bigdsz's Avatar
Bronze wool might work better.
