slave cyclinder done?
Old Jan 8, 2009 | 07:32 PM
1'low92's Avatar
Default slave cyclinder done?
My clutch stick to the floor and I get A soft pedal . What is a good brand to get for a replacement one... Thanks
Old Jan 8, 2009 | 09:53 PM
NBM-LS1's Avatar
Did you flush the fluid yet?
Old Jan 8, 2009 | 10:13 PM
dshag's Avatar
definately try the fluid and master cylinder before secondary, had same issues and got my fluid changed and master replaced and it works perfect. About 200 bucks for parts and labor at a shop. Slaves are expensive to do cause you have to drop the engine so just do the clutch and slave at the same time
Old Jan 9, 2009 | 12:51 AM
Jerrod4567's Avatar
Drop the engine? Did you mean tranny?
Old Jan 9, 2009 | 03:23 AM
beezer1519's Avatar
hopefully he did
Old Jan 9, 2009 | 04:58 PM
1'low92's Avatar
No I have not flushed the fluid yet. I'm going try that. What master cylinder is a good replacement.
Old Jan 9, 2009 | 07:07 PM
cenTX-LS1's Avatar
Check out the tick adjustable master. They are a sponsor on the right.
Old Jan 9, 2009 | 10:34 PM
1'low92's Avatar
Thanks. I heard a bunch of good things about the. I'll check em out
Old Jan 10, 2009 | 04:29 PM
1'low92's Avatar
Just a quick question is it possible that.
Maybe the pressure plate is bad?
Old Jan 10, 2009 | 09:31 PM
ImTheCeo's Avatar
That is a possibility but you need to drop the tranny to check it. As stated previously, its probably best to bleed the system and upgrade the master before it starts eating your clutch away.
Old Jan 11, 2009 | 12:55 PM
1'low92's Avatar
anyone have a pic of the bleeder screw im doing it right now trying to see what im going to be looking for .
