t-5 ??
Old Jan 10, 2009 | 10:02 AM
topspeedgt's Avatar
Question t-5 ??
i own a 95 mustang gt and i blew my trany out and a buddy of mine had a fox body one out of a 91 and he said if i use the bell houseing off of a 91 it will work. but i herd if wont. does any one know if it will work??
Old Jan 10, 2009 | 10:44 AM
Gen414's Avatar
PM "thesource" as he knows all these part numbers and such on these trannies, what will work, what won't, etc...
But, your 95 has teh 302 in it, and so does the 91 obviously, and teh clutch was the same so I see no reason why it would not. I know the 95 is the SN chassis and teh 91 teh Fox, but again, it was teh same tranny/motor. But, I would PM "thesource" anyways to verify
Old Jan 10, 2009 | 10:52 AM
thesource's Avatar
You can also swap the input shaft and bearing retainer over from your SN95 unit if its in good shape and the fox body unit will work .
Old Jan 10, 2009 | 02:01 PM
topspeedgt's Avatar
yea. well i put the trany and bell houseing in my car and the whole shiter sits like a inch forword. and it was hard as hell to get the crossmember on. and the trany wines really really loud. idk. i just think i need to buy a new trany for the year of my car. but thanks for all the help..
Old Jan 11, 2009 | 10:08 AM
Gen414's Avatar
Thesource is right, input shaft needs to be changed out. I did some research on this last night, and the input shaft is gonna be different.
Old Jan 12, 2009 | 12:32 PM
Bangin Bob's Avatar
Topspeed you have a pm thanks Bob
Old Jan 12, 2009 | 02:23 PM
Gen414's Avatar
Now, are you the REAL Bangin Bob? As in Bob Hanlon? If so, WELCOME!!
Old Jan 12, 2009 | 09:56 PM
Bangin Bob's Avatar
Originally Posted by gen414
now, are you the real bangin bob? As in bob hanlon? If so, welcome!!
Yes that would be me. Just checking out what's going on over here with you Chevy guy's.Thank you for the warm welcome. Thinking about being a sponsor here. Just became one over on www.njfboa.org a local site for us. Have been hearing alot of good stuff about ls1tech.
 Michael S. Palmer
Old Jan 12, 2009 | 10:08 PM
Gen414's Avatar
Hey, I am a CAR guy (hence my LSx motor going into a Fox Body) I ran Fun Ford WAY back in the day, starting @ '92. Ran Street Stock and held MPH record in 92 (or was it 93) Stepped up to Street 5.0. Then it was Street Outlaw. When we ran Street Outlaw, CI limit was 360 for ANY FI (Nitrous, Blower, Turbo) So, my friend that helped me with the MPH record decided to pull our resources together and build a REAL motor (Ford Motorsport Siamesed block, Windberg Crank, GRP's, J&E's, Neal BF200's, Dry Sump) build for nitrous. And that offseason, they changed teh Nitrous CI limit to 650" WE WERE PISSED!!!! So, after spending BIG money to build a combo that was obsolete before it was even finished really put a damper on things. I think that was 97, maybe 98, and we called it quits and just went had some fun.
Glafd to have you aboard BB!!
Old Jan 19, 2009 | 04:28 PM
topspeedgt's Avatar
insted of changeing the input shaft can i just swap bell houseings??
topspeedgt's Avatar
bump...
Old Jan 19, 2009 | 04:38 PM
thesource's Avatar
You can use a fox body bellhousing but you will need a fox body clutch fork and a driveshaft spacer as well .
Old Jan 20, 2009 | 08:32 AM
1234lt1's Avatar
HUh? the fox trany is already in the car so obviously it works
Old Jan 20, 2009 | 08:20 PM
topspeedgt's Avatar
yea the trans is in my car. but it wines really loud and dont want to go in gear.
