M6 Problem
Old Jan 10, 2009 | 04:39 PM
mrsracing's Avatar
Default M6 Problem
I have a 02 T/A WS6 with the 6 speed trans. My 5th gear grinds and is very hard to find and many times can't be found while driving whether simple smooth shifts or quick run thru of the gears. Do I need a complete trans rebuild, is it possible just to replace the gears for 5th, is there something else that may be happening? This car is equipped with the skip shift but I don't believe this has anything to do with the 5th gear problem. All other gears and shifts are ok.
Old Jan 10, 2009 | 04:46 PM
85MikeTPI's Avatar
Most likely the 5th gear blocker/synchro is bad. It's in the tail housing, so you wouldn't have to do a complete teardown/rebuild if you didn't want, but it's always a good idea when you're that deep into it anyway.
