switch on the clutch pedal?
Old Jan 12, 2009 | 06:31 AM
1FST99Z's Avatar
Default switch on the clutch pedal?
there is a vent tube on the switch on the clutch pedal. there are two switches one when you press the clutch down it engages and the one I am talking about is when you release the clutch it is engaged. But there is no pipe or hose that I have found under the dash. is this correct or do I have somthing missing.
thanks
Old Jan 12, 2009 | 10:32 AM
the_merv's Avatar
Veteran: Air Force
You got a pic bro?
Old Jan 13, 2009 | 08:50 PM
AllThrottle4U's Avatar
Why are you looking for a pipe or a hose under the dash? The switch that you see when the clutch is fully depressed is there to prevent the car from being started without the clutch in. The switch that at the top is for the cruise control. When you have the cruise set and you press in the clutch or the brake the cruise goes off. You might be talking about the pipe or hose that goes on the back of the master but can only be seen from under the hood.
Old Jan 14, 2009 | 05:13 AM
1FST99Z's Avatar
there is a vent on top of the cruise control switch. and I have never looked too hard at the wiring under the steering column.
Old Jan 14, 2009 | 09:33 PM
You mean for the a/c
Old Jan 17, 2009 | 04:25 PM
1FST99Z's Avatar
no, not the ac vent. if you look at the clutch pedal. the clutch pedal hits a button when the clutch is disengaged that is the one I am talking about.
Old Jan 17, 2009 | 04:51 PM
the_merv's Avatar
Veteran: Air Force
I know there is a black one that is on it..that's the N/S Switch, then the one white one is the Cruise.
Post a pic?
Maybe it's for the Flux Capacitor.
Old Jan 17, 2009 | 06:00 PM
Man, I don't know what to tell you. I just took my kick panel off to look under there for a hose or a vent and I don't see anything but the wires coming from both switches. What is it you are trying to achieve? Do you have a hose under there that needs to be connected to something? Do you have a loose wire that you can't figure out where it goes? Is it a vacuum hose size or a bigger hose like 3/8? How is you heater and a/c working?
