Difference in flywheel weights... and "seat of the pants"
Obviously, there is a huge difference between stock and aluminum, relating to quick revs and launching at the track, since aluminum weighs only half or so of stock
But how noticeable is the difference between the billet and the chrome moly, assuming its about 3 lbs (18 versus 15, respectively). Will the 3 pounds make a noticeable difference in the quick revs and/or launching? I'm talking seat of the pants. And will the 18 lb billet steel rev noticeable quicker than stock?
If what I've read is correct, 10lbs of rotational mass(ie: most things on the drivetrain) is equal to 100lbs of static weight. Meaning, if we take the theory that 100lbs is equal to .1 seconds on the quarter then every loss of 10lb rotational mass should theoretically gain you .1 seconds at the strip.
while i could tell a difference it was NOT a night and day difference. it did rev faster but as far as feeling it SOTP in a race situation, i just barely could tell.
so the difference from a 3lb change probably would NOT be noticable.
although there are guys who say they can fell the power difference from doing a throttle body bypass.....3hp
granted there are other mods...but i think my torque will jump more from the flywheel than it would with the other mods.
seems i remember the dyno comparison of the alum driveshaft resulting in more torque but nearly 0 hp gain.
- probably not a discernable difference between the 18 lb and 15 lb
- maybe some difference between the stock and 18 lb
- probably a noticeable difference between the stock and 15 lb
As far as the SOTP for power...I didnt notice anything substancial. Nothing worth noting.
As far as SOTP for drivability...BIG difference. The alum. flywheel made driving in traffic alittle touch and go. Launching required more revs than with the heavier wheel. There was no way to just ease the clutch out and start moving with the alum. I mean..you could, but it was a pain. Now, I can pretty much start off from a light with no gas.
I liked the alum...but ILl never go back. If anything, Ill find a middle ground somewhere because the LS7 set up is definetly a boat anchor. Heavy as heck.
J.
stock i could just let the clutch out easy, and it would pull out from a stop. but the alum fw just stalls out. some of this could also be due to having a race oriented clutch disk (stg 4 with no sprung center hub).
you most def have to give more revs to pull out
and i also agree with how fast the car runs to redline once the tires break free. i guess without really thinking about it much i assumed it was due to the power i was making. but the faster reving of the light FW makes sense too.
down shifts are nice, if you like to throw it through the curves. a light tap of the throttle to rev match and release the clutch. not as much of a jolt when dropping gears at above normal
speeds/rpms.i notice it alot more when i drop 4th to 3rd to pass someone...i generally don't rev match then since i'm in a hurry...it just snaps to speed and i'm pinned to the seat.
....with the TDs wailing!!!if you are really in tune with how your car feels under WOT, or in a drag race situation, you probably will notice a considerable difference going from stock to any light flywheel setup. say if you hit the track weekly, but i've never had my car at the track in almost 6 yrs. and all i do around town is slow starts...and fast shifts for 1 or 2 gears.
I might be crazy here...but I felt that my trans was alittle smoother with the light set up. Could just be the perception from the snappier revs...or my hydraulic issues etc etc. Just something I noticed when I did my second build and installed the LS7 clutch.
i did notice a slight increase in high frequency vibration after my clutch/flywheel install.
not sure it was the fw's fault...but with less mass to soak up vibration...its possible.
then again i've got poly motor, trans, and torque arm mounts
"Did you get it balanced?"
I had mine balanced and it was off quite a bit. I have poly motor, trans, and torque arm mounts too and it's very steady now, and the trans feels smoother. I'm running a Fidanza aluminum and SOTP was not noticeable but revs are lightning fast now; you have to be on your game to nail a shift at redline in 1+2.
Dropping 3 lbs? Probably wouldn't notice that as much.
that doesn't mean it couldn't have been balanced better....but oh well.
when i pull it out again...i'll have it redone...by that time it will be time for a new friction plate...
