Clutch Question???
Anyway, the clutch pedal has NO TOE play. The clutch doesn't engage until the pedal is almost all the way out. Something is definitely not right. The clutch does not slip in any gear. The current set-up just makes the person driving look like a rookie manual trans driver; lots of jerking.
Does this sound like a clutch bleeding problem or a possible clutch shim problem?
I appreciate any help/suggestions!
Thanks!
