what does shift skip means??
Old Jan 16, 2009 | 12:59 PM
gbal4's Avatar
Default what does shift skip means??
Hey guys this is new to me I noticed it the other day what does shift skip means am I doing something wrong while driving
Old Jan 16, 2009 | 02:36 PM
Sonic35SS's Avatar
You are not doing anythign wrong. The skip shift light will come on when you are trying to shift between 1st & 2nd gears, while going fairly slow. The computer would like you to go from 1st to 3rd gear. Sometimes you might notice that the it is difficult to get into 2nd gear when this light comes on.
There are some plug in modules that will eliminate that skip shift.
Old Jan 16, 2009 | 02:40 PM
99problemz's Avatar
i thought it was 1st to 4th?
Old Jan 16, 2009 | 02:47 PM
"Q"'s Avatar
"Q"
As did I
Old Jan 16, 2009 | 03:01 PM
danhr's Avatar
It means you just missed a gear.
Old Jan 16, 2009 | 03:17 PM
deelong4002's Avatar
its 1-4
Old Jan 16, 2009 | 03:18 PM
FiredUpZ28's Avatar
it is.
Old Jan 16, 2009 | 03:56 PM
Sonic35SS's Avatar
Sorry. I just knew it didn't want you going from 1st to 2nd.
Old Jan 16, 2009 | 04:13 PM
the_merv's Avatar
Veteran: Air Force
It means "Mod me".
Old Jan 16, 2009 | 04:17 PM
LtTransAm91's Avatar
Originally Posted by the_merv
It means "Mod me".
thats what i was to believe
Old Jan 16, 2009 | 04:22 PM
01Z28Camaro's Avatar
I'm still unclear what it means after reading all of that.
Old Jan 16, 2009 | 04:24 PM
bjamick's Avatar
It means that it makes you shift from 1st-4th gear while cruising. Its like the reverse lockout except for 2nd!!
Did that clear it up any?
Old Jan 16, 2009 | 04:36 PM
gbal4's Avatar
hey guys I get the idea thanks !!!!
Old Jan 17, 2009 | 08:11 PM
jcws6-25's Avatar
uuhhmm its in the lil book you should have in your glove box...called the owners manuel or something like that!!!lolol...and its 1-4......take a look!!!!!
good luck!
Old Jan 19, 2009 | 04:40 PM
sykodrummer9800's Avatar
? u had me thinkin i was wrong for a while.. i knew it was 1-4
Old Jan 19, 2009 | 08:15 PM
Shatterz's Avatar
Well to go into it a little more in depth, that "Skip Shift" feature was a rather ridiculous feature GM built into the the manual transmission (which I believe they still do on the newer models ??). Under certain conditions (35% throttle or less) the transmission is designed to force a 1-4 gear change to save fuel.
In reality this is ridiculous and unsafe in MANY situations when merging into traffic. To bypass it, just accelerate a little more briskly or the best thing to to is buy a inline harness from one of the many sponsors on here which plugs into the factory harness on the transmission that eliminates this annoyance. After doing so the light on the dash will still illuminate but can just be ignored and you'll have a much more enjoyable driving and shifting experience.
