Tuet 1260 to LS!
Old Jan 19, 2009 | 11:46 AM
kevtherev's Avatar
Default Tuet 1260 to LS!
Anyone know if this Ford intended box can fitted to an LS1 and what's needed?
Thanks.
Old Jan 19, 2009 | 02:24 PM
calhoon's Avatar
You will need to change the input shaft front adapter & bell.
You will need an input with the same 2.97 ratio ( Fcars are 2.66) A GTO input may work.
The rear mount and shifter location will not be correct.
There is no provision for the torque arm mount on the extension.
You will have to calibrate the speed output.
There is no skip shift connection.
It can be done with some effort. You might be better off trading it off & getting the right box.
Old Jan 19, 2009 | 04:29 PM
kevtherev's Avatar
Could a Ford centre plate be used with a GM pressure plate and thereby retain the input shaft? I guess speedo could be handled with an X box.
Old Jan 20, 2009 | 08:02 AM
calhoon's Avatar
Its not quite that simple. The pilot dia and the lengths are not common. Even the guide tube dia are different.
