rev matching??? pls respnd...
1) Press clutch in
2) Go into Neutral
3) Let Clutch out
4) Blip throttle to the new rpm where the lower gear will be at
5) Clutch in
6) Downshift to lower gear
7) Clutch out
If done correctly you should get a very smooth shift, but all this should be done in the blink of an eye
There is also a "easier" way, which isn't as forgiving to your drivetrain, but you will still get a smooth shift.
1) Press clutch in
2) Blip throttle to the new rpm where the lower gear will be at
3) Downshift to lower gear
4) Clutch out
From my research, the second method is alright to use when daily driving keeping rpms low >2-3k and just want to go to a lower gear for a bit more power. If you're doing a massive downshift(5-2) to get some serious power(a ricer tries to blow by you on the highway) you need to do the first method.
You should do some research before you laugh. Going into neutral and letting the clutch out reconnects the engine to the transmission which will make both spin when you blip the throttle. If you rev with the clutch in you are only spinning the engine side meaning you are not correctly matching both spinning components, just the engine side. For bigger shifts there is gonna be a larger inconsistancy in the turning rate between the transmission and engine leading to more wear if not revved with the car in neutral and clutch out.
Atleast this is what I have learned from asking and reading various forums.
Anybody care to comment?
wow, i feel dumb. lol i always thought rev matching was what i did on my limping trans. i used to clutch in, go to N and let the rpms drop to about 1k and then gently slide it into gear and my hurt synchros wouldnt grind.
Its easier on the blocker rings if you match rpms of to the gear you want. Rev matching with the clutch in only brings the engine up to speed not the input side of the trans. Now your relying on the blocker rings to match the input shaft speed to the output shaft speed (added wear). Now if you go into N with the clutch out then rev the engine your bringing the input shaft speed up with the engine. Now the input shaft speed is alot closer to the output speed for the gear your goin into making for a much smoother shift, (earlier example 5-2 downshift).
