Another Textralia Thread
I'm debating over the exo-skel, thanks in advance.
As far as this vote goes its referring to the Exo-Skel
ex:
a) Less Weight/Drives Better
"Exo-Skel is Less Weight/Drives Better then 0Z700 Z-Grip"
the spec 3+ is very drivable new full face design. still a on/off clutch have to be quick but not as bad as puck design clutches like the old spec 3
Pedal pressure is AS LIGHT or LIGHTER than stock.
Shifting in 2-6 gears is AS DRIVABLE as stock.
Getting out of first of course cannot be as drivable as stock, but still TONS better than both a Spec 3 and a Spec 3+ I used to have.
Between 1k and 2k RPM, the floater plate rattles a bit, but that is PURELY a noise issue, nothing to do with the way it drives.
I don't have massive power levels...about 390 rwhp. This clutch is an animal...it's heavy and it chatters like a **** in 1st and 3rd. It can be eliminated with more revs and quicker release, but then the tires spin...but that's OK since mine isn't a daily driver or even street legal.
It feels like if I shift hard that it will rip the rear axle clean out from underneath the car. Clutch grabs HARD at about the top 1/2" of pedal travel.
