M6 Blankets..SCATER SHIELD
Old Jan 22, 2009 | 09:55 PM
I8AFORD's Avatar
Default M6 Blankets..SCATER SHIELD
Who makes them?
blankets or what ever they are called
do they work?
Old Jan 22, 2009 | 11:24 PM
Joey@Tick's Avatar
LS1TECH Sponsor
We offer the Exotic Muscle T56 Bellhousing Safety Blanket for $179.95.
http://www.tick-performance.com/tick...rts/#hardparts
It is the only blanket specifically designed for the T56. Is it as good as a steel bellhousing? No. Does it work? It has to be better than nothing at all.
Old Jan 23, 2009 | 07:48 AM
85MikeTPI's Avatar
Originally Posted by I8AFORD
do they work?
They'll help protect your feet/legs from a clutch explosion.
They won't protect your block & trans from getting cracked if the clutch lets go.
They tend to collect oil/dirt and can be a fire hazard if you don't
keep and eye on them and periodically check/clean them.
Old Jan 23, 2009 | 08:24 AM
Jonathan@Tick's Avatar
LS1TECH Sponsor
If you've got the extra money, a steel bellhousing is a much better alternative IMO. As Mike said, the steel bellhousing also will protect the engine block (alteast the Mcleod does, I'm not familiar with others).
Neither one is a real picnic to install, the blanket is tough to get into place like it should be with the straps because of the steep slope of the belhousing. The steel belhousing usually requires modification to work with your headers, and on the earlier LS1's you actually have to swap the rear cover plate to a newer style which is thinner...
Old Jan 23, 2009 | 08:37 AM
Don@D&D performance's Avatar
LS1TECH Sponsor
I8AFORD:
Blankets are for automatic trans. only. We sell and stock the Quick Time Steel Bell Housing for your M6 Camaro. Call us at 248-735-6220.
Don @ D&D Performance.
Old Jan 23, 2009 | 08:52 PM
I8AFORD's Avatar
thanks for the advice guys
Old Jan 23, 2009 | 10:58 PM
1BADAIR's Avatar
correct
blankets are not legal for drag racing with a manual
I got my Quicktime from D&D
Old Jan 24, 2009 | 10:57 AM
LS1TECH Sponsor
Originally Posted by 1BADAIR
correct
Does the quicktime come with a plate to protect the back of the engine block? Just curious...I've never had the opportunity to install one yet.
Old Jan 24, 2009 | 11:06 AM
I8AFORD's Avatar
Originally Posted by Don@D&D performance
I8AFORD:
Thanks looks like a nice piece
does it come with the plate Like Janathon said?
Old Jan 25, 2009 | 01:23 PM
1BADAIR's Avatar
this is what they come with now
this was the early aluminum plate
Old Jan 25, 2009 | 02:54 PM
I8AFORD's Avatar
MCleod? do they make one ?
