I've tried everything.. Car still won't shift...
Old 10-06-2003, 03:22 PM
black00WS6's Avatar
Default I've tried everything.. Car still won't shift...
I've tried 3 different master cylinders and now just put in another new slave in it this past weekend (2nd 01 slave) The car first had a real soft pedal feel to it, then we rebled the master saturday with a mity vac for a good 30 mins. There were no air bubbles coming out at all. Put everything back together and still at high RPM's, the car takes a second or 2 to get into gear. Also on hard runs, the pedal loses most pressure and sometimes sticks to the floor. It is a lot better than before I put the new slave in but still is a PITA. Does ANYONE have any other suggestions that I can try before I sell this POS. A McCleod master? Another clutch? This clutch probably only has 4-6k miles on it and also the tranny was rebuilt the same time I put a new clutch in it.
Old 10-06-2003, 08:38 PM
SmaknaSS's Avatar
Default Re: I've tried everything.. Car still won't shift...
I have the same problem, I have a spec stg 3 clutch,Mcleod master,and slave ready to go in to hopefully rectefy this problem.Hope it works.
Old 10-06-2003, 09:44 PM
LS1Tech Sponsor
Slowhawk's Avatar
Sounds like your running a stock clutch?It's time for a new one.
Old 10-07-2003, 07:50 AM
black00WS6's Avatar
Nope, a cartek with about 4k miles on it. But it's done this since the day I put the clutch in, had tranny rebuilt, etc.
Old 10-07-2003, 08:29 PM
SmaknaSS's Avatar
ttt
Old 10-07-2003, 08:55 PM
P Mack's Avatar
Are you sure the fluid's not heating up from being too close to the headers/ AIR lines?
Old 10-07-2003, 10:41 PM
991LE's Avatar
If the clutch hasn't worked since day 1, then there might be something wrong with it.
From my experience, if the car NEVER shifts at high RPM, then it is a clutch problem. I am not certain what causes the pedal to stick to the floor, but when I removed my old spec clutch, with the sticking pedal, the PP was screwed up.
I really only had problems hitting 3rd with the stock master cylinder and before doing the drill mod. The drill mod and McLeod fixed the 3rd gear shifting problem.
EDIT<I don't have a cartek clutch, so maybe somebody with a cartek clutch will sound off>
Old 01-29-2004, 11:45 PM
blkbeaZ28's Avatar
Did you ever get this problem resolved if so what was it I am in a similiar bind
Old 01-31-2004, 05:49 AM
Formula 1's Avatar
I vote for a new clutch. Ram or Spec
Old 02-01-2004, 06:18 PM
greekss's Avatar
Default HUH ?>????
Ya i fell u guys.... after a hard run my pedal sticks to the floor briefly but it still does and randomly it wont go into third. I currently have an '02 with 18k on it. What am i lookin at ?????
Old 02-06-2004, 11:33 AM
35th SS's Avatar
wish I could help.I know when I first install mine the pedal would stick to the floor cause of leak problem.did the drill mod and mc leod master.was getting frustrated too.once had all my leak problem fix clutch works fine ever since.good luck
