Valeo clutches?
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Some clutch companies use the Valeo PP others the knock off's. Some say they adjust the angle in the "fingers" of the PP for more clamp force, Centerforce puts slider weights between the fingers of the PP.
What the major difference is between all the "brands" is clutch disc material & construction. Many to chose from
