Pull clutch to CSC?
It works but the action sucks and it is very heavy. I was hoping to convert to a later version that uses the concentric slave cylinder (CSC). Has anyone tried this on the early transmission? What parts did you use? Or do I need to swap out the factory bell housing to make it work? Is there an aftermarket solution?
Any tips would be great!
Thanks
