1998 z28 tranny problem please read
hello all i want to pick your brains for a sec, i have had this car for some time now, only replaced the clutch ounce. the other morning i went to leave for work, i could not get it into gear. so i played and played with it till i finally got it to get into gear and now when its in gear with the clutch pushed in, it sounds like there is rattling coming from the tranny now, but only with the clutch pushed. so throw some ideas to me. help me figure it out, thanks for all your help
when you push the clutch pedal down the release bearings presses against the diaphragm to release the pressure plate from the friction disc/flywheel, if the noise is only when the pedal is pressed then its more than likely the release bearing. now if you have trouble shifting into all gears then your clutch is worn or you have air in your hydraulic system, but im gonna say its your release bearing
