need help chosing gears in my99 ss m6 150k 4.10s???
I want to put gears in my car. like most i am looking to do it as cheepy as possible but want to make sure i do it all right. new bearing etc etc. should i go with 4.10s? if so what kind? a local shop here in baton rouge said they would do it but ofr round 1100. this seems pricy seeing how most gears cost 200 to 250ish. should i put them in myself and if so can any one give me help on how to.......
also the shop said they would use gm gears cuz they dont make noise like all the others. if i dont go with gm should i worry that they will be loud???
i just had my rear end completely rebuilt, and put in richmond 3.42s. Makes a whine noise starting at about 60. Nothing Some Dynamat cant fix. 410? I hope this isnt a daily driver.
it is a second car that i drive only so often. why do u say hope its not a daily drive? what will the gears affect? besides gas mileage and shifting more often?
You should post this in the rearend section.....But to help ya.....most shops charge between $250.00-$500.00 for gear installs....That is for labor only...$1100.00 is way too much for install....4.10's are fine for a dd.....
