replacing clutch....
Old Feb 5, 2009 | 06:32 PM
00TAM6's Avatar
Default replacing clutch....
if i were to replace my clutch.. and im planning on upgrading to a ls7 clutch.. will i need to upgrade my flywheel as well or can i use my stock flywheel and have it resurfaced? and or will i be needing anything else for a clutch upgrade? please let me know... thanks...
Old Feb 5, 2009 | 10:30 PM
NVR_SPDS's Avatar
If im not mistaken, you need an LS2 Flywheel to use the LS7 Clutch. I dont believe it will bolt to an LS1 flywheel.
Old Feb 5, 2009 | 10:48 PM
98camaro28's Avatar
You have to use an LS2 flywheel. LS1 flywheel won't work.
Old Feb 6, 2009 | 03:15 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
When you order the LS7 kit it comes with a flywheel. And no the LS1 won't work
