Clutch problem?
Old Feb 7, 2009 | 03:35 PM
stang56k's Avatar
Default Clutch problem?
Ok... When I get down on the car my clutch will stick near the floor and not come up, Sometimes it feels like it is bouncing a little like it has no pressure or something while its stuck and will not come all the way up. Also sometimes it will not go into gear and i have to release the clutch and press it again and it will go into gear. I do not have the drill mod and was thinking this might be the reason.
Old Feb 7, 2009 | 07:04 PM
BlkBird2000's Avatar
Quite a bit of power for a ls6 clutch. You have 315s and 4:10s which is harder on the clutch than street tires and smaller gears. If you do not plan to make anymore power I would upgrade to just the ls7 clutch.
