LT1 M6 conversion wiring problems?
Can anyone help me out here, I have the new pigtails for these 2 switches on the T56 and need to wire them up to the car but the directions I have from the Sticky section above doesn't have any pics just states that the polarity is needed and to attach 1 wire to the A side of the switch the other to the B side, there is no marking on the switches on my trans nor on the pigtails I got from GM and obviously the wires on the pigtails have the same color???? Top is the reverse lockout and bottom the VSS correct? I have the wires I need to attach to them from the original A4 harness and another wire I've added to the one PCM connector which was empty and extended up to this area, anything I'm missing here?
Could someone just slid under their car with a stock LT1 and T56 and just take the same picture as I have above? maybe the wiring colors and a factory diagram would allow me to figure this out??? Never mind the 12" of snow you would have to lay in to do this...
BUELLER BUELLER???
BUELLER BUELLER???
