Drill Mod Problem
Old Oct 13, 2003 | 12:16 PM
ZDOG's Avatar
Default Re: Drill Mod Problem
yep, you are correct part # 12570277 is the master,resevoir,and clutch line. now if i can find it local used that'll be great. btw my fluid was also black. by the time you get done bench bleeding itll be clear again at least for a little while.
Old Oct 13, 2003 | 02:03 PM
ZDOG's Avatar
just ordered a new one from gm sdpc performance parts. total is 168 for it to be overnighted. im real scared now to even attempt drill modding this one! so you guys have had good luck using a 7/64 bit? also what type of bit has a good twist strength? i do not want this to happen again nor will i feel good putting it back together un modded! no salvage yards with in a 2 hour drive has any late model f-body's so that means new yorkers are the best drivers i guess. closest dealer that has the part in stock is n PA. about 160 miles away. sorry for rambling im just fustrated. hmm what could i have done with 170.00? a new lid? ftra? it hurts to think about it. i hope i can feel the difference with this mod because it will probally make me feel better then. thanks for all the suggestions and support. ill update you tomorrow on the latest episode of "as the z turns"
Old Oct 13, 2003 | 02:21 PM
JRcamaroZ28's Avatar
I used a 1/8" bit from sears. i cant remember the type but it was gold in color and was in a gold/black pack. it cut the hole perfect w/ no binding at all.
JR
Old Oct 14, 2003 | 08:47 AM
Vents's Avatar
guys that need these masters, shoot me an e-mail. i've got them in stock, ready to overnight. ;D
Old Oct 14, 2003 | 09:25 AM
ZDOG's Avatar
do you have the lines with them? i already ordered but if i fubar this one ill give you a holla!
Old Oct 14, 2003 | 05:09 PM
ZDOG's Avatar
ups sucks. next day means lets misplace it till the next day. i seem to have the best luck.
Old Apr 1, 2014 | 06:05 PM
shawnolin's Avatar
Hey how much for the master? With the line? I also need a new line because my bit broke off to
Old Apr 1, 2014 | 06:16 PM
LLave's Avatar
haha.. best use high quality drill bits.
Old Apr 1, 2014 | 06:20 PM
1nverted's Avatar
This thread is from 2003
Old Apr 2, 2014 | 10:15 AM
demonspeed's Avatar
It's not mine! woo hoo!
If only I had mod powers in this section
