noisy tob?
Old Feb 15, 2009 | 11:29 PM
slayerized6's Avatar
Default noisy tob?
on Friday afternoon i got a ram adjustable master installed in my 98 trans am. on the way home i noticed my tob/clutch was noisy when stopped in neutral at red lights and stop signs. (fyi, its a spec stage 1 with approx. 9k miles on it.)
saturday morning, i realized the new master cylinder barley had any free play so i adjusted for more.
when i was driving the car around sunday, the clutch/tob assembly was making all sorts of noises. when sitting still in neutral, with the engaged, there a noise coming from the transmission area. disengage the clutch, the noise goes away. during moderate accelleration, there a 'scuffing' noise coming from the transmission area. the same scuffing is heard slowing down, while in gear.
so whats the problem here? im guessing a worn TOB? possibly the slave?
Old Feb 16, 2009 | 03:22 PM
bumppp
Old Feb 17, 2009 | 05:56 PM
LS1powerhouse02's Avatar
I am curious as well. This sounds sort of like the noise I am hearing. Mine came on gradually and has gotten louder.
It only does it when the clutch pedal is up. When you push the clutch pedal to the floor it stops. When I drive though it makes no noise unless I am rolling up to a stop light real slow.
Old Feb 18, 2009 | 04:07 AM
casca2001's Avatar
ttt, having similar issues
