slave?
Old Feb 16, 2009 | 05:18 PM
brandon janeway's Avatar
Default slave?
Just installed new clutch/slave and it has started leaking fluid out of the slave. will i have to replace the hydraulics or is there another way to fix?
Old Feb 16, 2009 | 05:34 PM
rollinna65's Avatar
Where is the fluid coming from? Is it coming out of the hole in the bottom of the bellhousing or somewhere else? Check and make sure you've got the bleeder tightened all the way and then check your master's braided line to see if you damaged it at all during the install. Get the little stuff out of the way first and then go from there.
Old Feb 16, 2009 | 07:11 PM
Its dripping out of the bottom of the bellhousing, just confusing cause it drove fine for couple of days then started this all at once.
