GTO Tranny problems?
Old Feb 22, 2009 | 12:44 AM
mr_biscuitz's Avatar
Default GTO Tranny problems?
Alright Im posting this for a buddy but anyways any help would be much appreciated. The car is a 2005 m6 gto with heads/cam fast90/90 with drag radials and some suspension. The car ran a best of 11.93 @115 untuned. Anyways the car just started having problems shifting into 3rd gear under hard exceleration, well he ended up fixing that problem by buying a new slave but now it slips really bad at 6k rpms no matter what gear your in. The car has like maybe 15k on it and the clutch is a stock piece. Thanks for any tips or answers to the problems.
Old Feb 22, 2009 | 01:05 AM
rollinna65's Avatar
That's just the way it goes with all that power and a stock clutch. He fixed the hydraulic problem which revealed his inadequate clutch. Upgrade that thing and he should be good to go.
Old Feb 22, 2009 | 08:37 AM
85MikeTPI's Avatar
Did you put a shim behind the new slave, or do the slave-shim measurements in the sticky? Sounds like your not fully disengaging the clutch, causing the slipping, since it happened after the slave change.
