tranny problem help
Old Oct 14, 2003 | 10:55 PM
avezz28's Avatar
Default tranny problem help
I have a stock transmission with an aftermarket SLP shifter. The car will not go into 5th gear when downshifting from 6th. It doesn't clunk or grind. It just does not go as if the gate is closed. The car shifts fine when going from 4th to 5th though. Please help with identifying my problem and how I can fix it. Thanks in advance.
Old Oct 15, 2003 | 12:51 AM
2002SilverWS-6's Avatar
Default Re: tranny problem help
Since you have a 2002 take it back to the dealer and get it fixed under warranty.
Old Oct 15, 2003 | 06:22 AM
991LE's Avatar
What he said
Old Oct 15, 2003 | 10:26 AM
Scalpel's Avatar
Yep yep, get a new tranny put in
Old Oct 15, 2003 | 02:34 PM
avezz28's Avatar
Yup that is what I was thinking but I'm afraid they wont work on it under warranty because of the modifications to the car. I guess it is worth a try though.
Old Oct 16, 2003 | 06:58 PM
Look at the mods on my car. I got a new clutch, pressure plate, throwout bearing, flywheel, slave cylinder, hydraulics, and actuator last week all under warranty.
