quick ? on current install of master?
Old Oct 15, 2003 | 05:28 PM
ZDOG's Avatar
Default quick ? on current install of master?
does anyone know .... with the clutch master cylinder does the steel braided line go on top or below the steering linkage before i battle this thing all night?
thanks
Old Oct 16, 2003 | 08:08 PM
SSEUL8R's Avatar
Default Re: quick ? on current install of master?
below the steering column. Make sure you get it under that heat shield or you will have trouble shifting at high rpm due to the fluid heating up
