Question on F-body factory shifter orientation for T-56
Old 02-28-2009, 01:44 PM
grobb284's Avatar
Default Question on F-body factory shifter orientation for T-56
Every shifter I have seen for the F-body T-56 transmission has a shifter as in the photo below. It has the flat on the shifter arm mount in line with the axis of the transmission. Mine is a factory shifter, but I have pictured a Hurst below which is similar.
I picked up a t-56 for the F-body as a box of parts. It has the factory shifter similar to above, BUT the flat for the shifter arm mount is rotated 90 degrees clockwise from the photo above.
Is there some way that when the shifter is removed from the transmission that the shaft for the shifter arm can be rotated? I tried gently turning it, and it seemed solid, so I stopped.
Any suggestions?
Old 02-28-2009, 04:26 PM
ElkySS's Avatar
im pretty sure you knew this already but just in case, thats not a t-56. i believe its a t5
Old 02-28-2009, 07:48 PM
grobb284's Avatar
You are correct, I have changed the photo as to reference the orientation of the flat on the shifter.
Do you know how the flat can be reoriented on the factory shifter so it is same as the Hurst unit above?
Old 03-01-2009, 07:31 PM
grobb284's Avatar
Anyone help me with this?
Old 03-02-2009, 07:47 AM
85MikeTPI's Avatar
Can you take/post a picture of the shifter you're asking about? It could be from a different type of vehicle, or it could just be the rivets have loosened and the mechanisim has rotated.
Old 03-02-2009, 12:45 PM
calhoon's Avatar
The factory Fcar shifter has the stub lever in the same orientation as the Hurst( actually a factory -offered Hurst) in your picture. If yo have a shifter with the lever90 degrees off, it is not an Fcar shifter.
Old 03-04-2009, 08:50 AM
grobb284's Avatar
Just posted photos of the shifter here:
Shifter Photos
Old 03-04-2009, 01:58 PM
calhoon's Avatar
See your other post - you have an SSR trans.
Quick Reply: Question on F-body factory shifter orientation for T-56
