Check out my new Centerforce clutch
Old 03-04-2009, 01:10 AM
BuffJoeyD's Avatar
Default Check out my new Centerforce clutch
Pulled my trans out tonight cause I wanted to see why under normal driving the clutch wouldnt hold any power- just started to slip- Happened during a car cruise- Casual driving.
They almost look cut- I say manufacture defect- What say you? Put this clutch in before driving out to LA invasion- 500 mile super casual break in. Took it to LA invasion and did 3 track passes - 2 18 second pass shut down runs from no traction: after 2000 miles. ( freeway cause the 400 goin out to LA and the cruise) 400 miles back from LA invasion. Car stayed down for like 3-4 months while the car was torn completly down and heads / suspension were installed.
So not even 6 months of driving, and a few more track runs in Vegas. 400 hp 3200lb car. Clutch dies on street driving after 10 months of ownership.
Tick master new slave installed with clutch. thx for reading - thats all.
Attached Thumbnails Check out my new Centerforce clutch-0303092245a.jpg   Check out my new Centerforce clutch-0303092247a.jpg
Old 03-04-2009, 05:56 PM
SNLPerformance's Avatar
I'm sure the guys out at Centerforce will get you taken care of, keep us posted!
Old 03-04-2009, 06:32 PM
BuffJoeyD's Avatar
Gotta figure out who and how to contact- Havent seen them on Ls1tech since December.
Old 03-04-2009, 07:52 PM
LS1powerhouse02's Avatar
Are you talking about the wire? If so dont they look like that from the factory? Maybe I am wrong. I cant remember what mine looked like anymore.
Try to pm Will Baty. Do a search on here and he should come up. He is with Centerforce and has helped me out with a problem I had.
Old 03-05-2009, 01:34 AM
BuffJoeyD's Avatar
yeah, I kno wills screen name, hasnt been online since december.
Old 03-05-2009, 06:10 AM
Arc00TA's Avatar
They do look like that. It is a counterweight design that helps with clamping force as rpm increases. Obviously his were not working as advertised. Good luck, hopefully they sort you out.
Old 03-05-2009, 06:49 AM
that sucks. Sorry man i tried.
