Clutch & Flywheel differences??
Old Mar 11, 2009 | 10:02 AM
Racinjason424's Avatar
Default Clutch & Flywheel differences??
I've researched this forum, as well as the Conversion fourm and my fingers are raw from searching, so I thought It was time to ask!
What is the difference between a Camaro and Corvette Flywheel & Clutch? I noticed when buying aftermarket parts they list different part numbers for say a 98-02 Camaro and 97-04 Corvette.
The reason that I am asking, is that I am in the process of installing a '04 C5 Corvette LS1 in my '69 Camaro and I need a clutch and Flywheel setup.. I have a friend that has a new Spec aluminum flywheel and Stage 3 Clutch for a 98-02 F-Body Camaro that I can buy and I was wondering if that would work on my '04 C5 LS1.. I plan on installing in my TKO-500 w/ tremec hydraulic clutch kit and Lakewood scatter sheid.. I do know the TKO has the same 26 spline count as the Spec F-Body clutch and I will have to use a long pilot bushing.. Apprecaite any info.. Thanks, Jason.
