SES light during high RPM shifts-->
Hi. I seem to have a problem with my car that I just cant figure out: When I shift at full throttle or almost full throttle, the SES light will come on. Most shifts are around 4700-6000 rpm when this happens. I dont have a way to read the code, but was wondering if anyone would have any ideas as to what the problem may be. I've already tried replacing the TPS sensor, but no luck. After about 3 or 4 driving cycles, the light will go off. Like I said the only conditions that this occurs under are full throttle (or near) and at higher RPM shifts. Car and mods in sig. Thanks.
if you just start replacing parts without having an idea you may never get it fixed. anytime the ses light comes on and then goes off it still stores memory codes. your best bet will be to find someone with a tech 2. or a scanner that read memory codes. tech 2 will be better because you can have some one ride with you and read the data when the ses light comes on. hope this helped a little.
miles
miles
The Throttle Position (TP) sensor is a potentiometer. The TP sensor is mounted to the left side of the throttle body. The TP sensor provides a voltage signal that changes relative to throttle blade angle. This signal voltage is one of the most important inputs used by the PCM. The TP sensor has a 5.0 volt reference, a ground and a signal circuit.
The TP sensor signal voltage should be about 0.6 volt at idle. The TP sensor voltage should increase to above 4.0 volts at wide open throttle (WOT).
When the PCM senses a signal voltage higher than the normal operating range of the sensor, this DTC sets.
Conditions for Running The DTC
The ignition switch is in the ON position or the engine is operating.
Conditions for Setting The DTC
• The TP sensor signal voltage is greater than 4.8 volts.
• Condition present for 10.0 seconds.
Action Taken When the DTC Sets
• The PCM illuminates the Malfunction Indicator Lamp on the second consecutive ignition cycle that the diagnostic runs and fails.
• The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure records.
• The PCM uses a default TP sensor value.
• The Transmission TCC will not apply.
• High transmission line pressure.
• Fixed transmission shift points, hard shifts and no fourth gear in hot mode.
Conditions for Clearing the MIL/DTC
• The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
Important:
• Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing/replacing the PCM. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM.
• For any test that requires probing the PCM or component harness connectors, use the Connector Test Adapter Kit J 35616 . Using this kit prevents any damage to the harness connector terminals.
• The following may cause an intermittent:
- Mis-routed harness
- Rubbed through wire insulation
- Broken wire inside the insulation
• The PCM 5.0 volt reference circuits are internally connected within the PCM. If all the TP sensor circuits are OK, inspect the Fuel Tank Pressure Sensor for malfunctions.
• If it is determined that the DTC occurs intermittently, performing the DTC P1121 diagnostic table may isolate the cause of the fault.
• For an intermittent, refer to Symptoms .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
If DTC P1639 sets at the same time, this indicates that the 5.0 volt reference circuit is either shorted to a ground or shorted to a voltage. The 5.0 volt reference circuit is internally connected within the PCM.
This step verifies if the fault is present.
Using Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicated the DTC, the information included in the Freeze Frame and/or Failure Records data can help determine how many miles since the DTC set. The Fail Counter and Pass Counter can also help determine how many ignition cycles the diagnostic reported a pass and/or a fail. Operate vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature etc.) that you observed. This will isolate when the DTC failed. For an intermittent condition, refer to Symptoms .
Vehicles equipped with traction control will have to disconnect the Accelerator and Servo Control Module. This will determine if the short is caused from the Accelerator and Servo Control Module. After repairs are made, reconnect the Accelerator and Servo Control Module and clear the DTCs that set when the Accelerator and Servo Control Module was disconnected.
This tests whether the ground circuit is available to the TP sensor. Test for poor electrical connections at the TP sensor. Refer to Repairing Connector Terminals in Wiring Systems.
Step
Action
Value(s)
Yes
No
1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
Install the scan tool.
Idle the engine.
Monitor the Diagnostic Trouble Code (DTC) information using the scan tool.
Did DTC P1639 fail this ignition?
Go to DTC P1639 5 Volt Reference 2 Circuit
Go to Step 3
3
Turn ON the ignition leaving the engine OFF.
With the throttle closed, observe the TP sensor voltage and percentage display on the scan tool.
Is the TP sensor voltage or the Throttle Angle above the specified values?
4.7V, 0%
Go to Step 5
Go to Step 4
4
Review the Freeze Frame and/or Failure Records data for this DTC and record the parameters.
Turn OFF the ignition for 15 seconds.
Start the engine.
Operate the vehicle within the conditions required for this diagnostic to run, and as close to the conditions recorded in Freeze Frame/Failure Records as possible. Special operating conditions that you need to meet before the PCM will run this diagnostic, where applicable, are listed in Conditions for Running the DTC.
Select the Diagnostic Trouble Code (DTC) option, the Specific DTC option, then enter the DTC number which was set using the scan tool.
Does the scan tool indicate that this diagnostic failed this ignition?
Go to Step 5
Go to Diagnostic Aids
5
Important: After you complete this diagnosis reconnect the Accelerator and Servo Control Module. Also, clear the Accelerator and Servo Control Module DTCs that set when the Accelerator and Servo Control Module was disconnected.
Turn OFF the ignition.
Disconnect the Accelerator and Servo Control Module. Refer to Accelerator and Servo Control Module Replacement in Antilock Brake System.
Turn ON the ignition.
Is the TP sensor voltage above the specified value?
4.7V
Go to Step 6
Go to Diagnostic System Check in Antilock Brake System
6
Disconnect the TP sensor electrical connector.
Observe the TP sensor voltage display on the scan tool.
Is the TP sensor voltage below the specified value?
0.20V
Go to Step 7
Go to Step 10
7
Probe the sensor ground circuit at the TP sensor harness connector with the test lampJ 35616-200 connected to B+.
Does the test lamp illuminate?
Go to Step 8
Go to Step 11
8
Measure the voltage at the 5.0 volt reference circuit to ground using the DMM J 39200 .
Is the voltage greater than the specified value?
5.0V
Go to Step 14
Go to Step 9
9
Replace the TP sensor. Refer to Throttle Position Sensor Replacement .
Is the action complete?
Go to Step 15
10
Disconnect the PCM connector C2 located on the same side of the manufacturer's logo. Refer to Powertrain Control Module Replacement/Programming .
Test for a short to voltage on the TP sensor signal circuit; also test for a short circuit between the TP sensor signal circuit and the Accelerator and Servo Control Module.
If you find the TP sensor signal circuit shorted, repair the circuit as necessary. Refer to Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 15
Go to Step 13
11
Test for an open TP sensor ground circuit. Refer to Testing for Continuity in Wiring Systems.
If you find the TP sensor ground circuit open, repair the circuit as necessary. Refer to Wiring Repairs in Wiring Systems.
Go to Step 15
Go to Step 12
12
Test the TP sensor ground circuit for a poor connection at the PCM. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
If you find a poor connection at the TP sensor ground circuit, repair as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Go to Step 15
Go to Step 13
13
Important:: Program the replacement PCM. Refer to Powertrain Control Module Replacement/Programming .
Replace the PCM.
Go to Step 15
14
Repair the 5 volt reference circuit for a short to voltage. Refer to Wiring Repairs in Wiring Systems.
Go to Step 15
15
Select the Diagnostic Trouble Code (DTC) option and the Clear DTC Information option using the scan tool.
Idle the engine at the normal operating temperature.
Select the Diagnostic Trouble Code (DTC) option and the Specific DTC option, then enter the DTC number using the scan tool.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test ran and passed?
Go to Step 16
Go to Step 2
16
Select the Capture Info option and the Review Info using the scan tool.
Does the scan tool display any DTCs that you have not diagnosed?
Go to the applicable DTC table
System OK
Diagnostic Aids
Important:
Test Description
Step
Action
Value(s)
Yes
No
1
Go to Step 2
2
Idle the engine.
Go to Step 3
3
4.7V, 0%
Go to Step 5
Go to Step 4
4
Start the engine.
Go to Step 5
5
4.7V
Go to Step 6
6
0.20V
Go to Step 7
Go to Step 10
7
Go to Step 8
Go to Step 11
8
5.0V
Go to Step 14
Go to Step 9
9
Go to Step 15
10
Go to Step 15
Go to Step 13
11
Go to Step 15
Go to Step 12
12
Go to Step 15
Go to Step 13
13
Replace the PCM.
Go to Step 15
14
Go to Step 15
15
Go to Step 16
Go to Step 2
16
System OK
