t56 questions ..
Does the lt1 (93-97) share the same bellhousing as the ls1? also is the 89-96 corvette 6 speed the same?
also is the t56 the only option for the ls1? Im wondering about like a t5 or another 5 speed....
and if anyone is interested, and lives near asheville nc. would like to swap my low milage automatic from a 99 camaro for their 6 speed, I will pay for ALL labor to have them swaped over
I don't believe 300hp/330flbs is going to hurt a t5, older camaros ran them for years on the l98 tuned port, with more TQ then an ls1. and the mustang guys put some serious HP to a t5.. I don't believe them to be as strong as the ZF six-speed or the 1st gen t56.. but they would hold up fine to stock/bolt on ls1.
I was debaiting a t5 over a (98-02) t56, because Ive been reading about how the newer t56 transmissions are made in mexico and a very weak.
so from what whats posted, the ls1 has its own transmission? the older t56 will not bolt up, only the ls1 t56?
just a gen swap question, what do I do about the PCM? Do i need to change it to a 6speed ls1? or can I keep the automatic/ls1 pcm? what should I do about the wires going to the a4? Does the 6speed pedels bolt up to an automatic car?
That being said,
93 LT1 by itself
94-97 LT1 are the same
98-02 LS1 are teh same.
You can not get a '93 to bolt to a LS1 tranny.
To get a 94-97 LT1 tranny to bolt to a LS1, you need:
LS1 bellhousing
LS1 Midplate
LS1 input shaft
LS1 Hydraulics
LS1 flywheel, clutch and PP
