cllutch slip question
Old Mar 13, 2009 | 10:56 PM
Jayh's Avatar
Default cllutch slip question
This is my second spec stage 3 clutch, been installed for 2 yrs on a 2000 Z28. I put a new flywheel and new slave and master when I put it in. In 6th gear at 70 MPH roughly 1700 RPMs, I can push the gas and the car will vibrate and the RPMs rise but the car doesnt accelarate. Is it the throw out, slave or the clutch slippn. Its fine in low gears and high RPMs, but low RPMs in high gears, it slips and vibrates. Dont really want to spend another 700 on parts and labor.......
Old Mar 14, 2009 | 02:28 AM
red02Hawk's Avatar
yep the clutch is slipping, wear and tear maybe, should be able to just buy a new disc and resurface the flywheel, while you're there you can go ahead and replace the rear main seal. My rear main went out on me and caused my clutch to slip.
Old Mar 14, 2009 | 11:56 AM
wrencher's Avatar
wrencher
Sounds like it's slipping for sure. Not another spec maybe?
Old Mar 23, 2009 | 03:57 PM
Jayh's Avatar
on my last replacement, it was a slave failure....do ya think the clutch is warn or could it be another component issue ?
