Transmission Carnage (pics inside)
Before ordering, give me a call. I can probably save you money! I keep this stuff in stock at all times. Here is what I recommend...
All new middle (friction) and outer rings, all new fork pads, keys and springs. Looks like you also need 2nd gear (judging by the rounded off points). You might also need a 1-2 hub/slider assembly. Let me know if I can help! My info is in my sig.
-Jason
-Jason
Thanks, Jason!
3rd ring appeared to be fine. What about the Textralia makes you think it's the cause of the problem? It happened on a shift with the clutch engaged (clutch pedal to the floor). I was having clutch disengagement issues for a long time, so I have a feeling that's when most of the other damage happened (and possibly what started this issue).
CARTEK Racing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I always wonder why some people break T-56's so easily? I have close to 400 passes on my stock T-56, stock, 3 different H/C setups, H/C+N2O. Launching at upwards of 7200rpm, powershifting at 7000rpm. Not to mention a long period of daily driving in typical NJ traffic, over 70K miles in total. And yet, I never had one hick up with the stock unit.
I realise that some people may say that "well you just got lucky" or "some are built better than others" but that can only go so far...
I honestly think that some people simply drive better than others, and can keep parts together better than others. I am not saying I am one of them, after all, I broke my 12-bolt 4 times, but never had an issue with the stock t-56.
I dunno... just makes me thing that maybe I agree with the joke. Either way, I am a stupid kid too.
Having said that, You can also contact Tick Shift, Joey and Jonathan are good people and always willing to help.
Good Luck!
#32
Internet Mechanic
I know this was a joke, but there is a small amount of truth in all jokes.
Good Luck!
Good Luck!
Drivers Ability is always a factor, Racing puts extra stress and opens it up to even further danger. I am of the feeling in most cases as long as I race my car the chance of blowing the trans every shift is prevelant.
A average driver, of average shifting ability, not racing the car should never have an issue, even with clutch fluid, any harder driving leaves a chance of hurting it.
I fully suspect at some point, that I am going to blow my unit, but im not there yet.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#33
Good Luck!
Good Luck!
I understand that if you've got someone who can't shift or is constantly missing gears, etc, that this will cause premature wear and tear on the trans internals, but I don't miss shifts with this car, I rev match, and I'm a pretty good driver (I'm not gonna say I'm the best or anything, but I do just fine). When the clutch isn't disengaging fully, it also causes premature wear and tear and if you don't resolve the issue no amount of "good driving" will prevent breaks. I was fully aware of the problem while driving it and that the breaks were bound to happen, but I got sick of letting the car sit all the time while trying to troubleshoot (I bought the car to drive it, not let it sit in the garage collecting dust).
We'll see how it goes when I get it all back together. The parts are scheduled to arrive Friday so barring any issues, I hope to have it back together and in the car Saturday night so I can test everything out Sunday (supposed to be a nice weekend!).
#34
CARTEK Racing
I'll mention again, for those who may have missed it, that I have been wrestling with some serious clutch disengagement issues, especially on high RPM shifts, ever since I've purchased this car (hence all of the different driveline setups I've tried). I just received a brand new Tick master cylinder yesterday that will be going in this car along with the new rebuild. I'll also be checking the pinion angle and installing a new crossmember to relocate the torque arm off of the tail of the transmission.
We'll see how it goes when I get it all back together. The parts are scheduled to arrive Friday so barring any issues, I hope to have it back together and in the car Saturday night so I can test everything out Sunday (supposed to be a nice weekend!).![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
I did not see the mention of clutch issues, that is what most likely have caused the damage inside the trans.
I guess I've just been lucky with my stock and CARTEK cluches.
Good Luck on the re-build!
#35
Im sorry if that came off as an insult. I was just making an observation. I know a bunch of guys who have gone through fully built transmissions like they were made out of paper.
#39
Internet Mechanic
I remember taking you out when I put the new TB on at I had a massive miss shift, grind.
Then started the High RPM shifting issue Saga, that concluded in late summer.
I do need a TQ arm mounted cross member, I picked up some extra work to pay for it. The car goes back on the road this weekend so I can get it inspected and through emissions.
#40
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
What happened to your torque arm mount? Someone mentioned something about it being broken or something? That BMR transmission crossmember mounted one looks like a mint piece of hardware. I was checking out the one that Joe bought.
In other news, I refilled the bottle and upped the window switch to 6400 rpms. The car pulls like bat out of hell now!
