help with Spec 3
Old Mar 15, 2009 | 06:57 PM
Clark Kent's Avatar
Default help with Spec 3
is there any specific things i should know when putting it in? It is in my garage, i remember last time i didnt line it up correctly and had to redo it. just line the holes up or what?
Old Mar 15, 2009 | 06:59 PM
Raven02TA's Avatar
well, are you using a clutch alignment tool? (usually it comes with the kit)
sometimes if the trans doesnt matte back up the clutch has to be re-aligned.
Old Mar 15, 2009 | 07:04 PM
RsSean's Avatar
Replace the slave while you are in there if you have not already. Make sure you do not need a shim using that clutch. So do some don't. There is a sticky that explains the how to measurement. Mine came with a new pilot bearing make suure you get that installed as well.
Old Mar 15, 2009 | 07:32 PM
Raven02TA's Avatar
you dont NEED to do the pilot as long as yours is good, they are a PITA to take out. so if its good, through some grease in it. you should be ok.
typically slaves dont go bad either. but if you accidentally put too much of a bind on it while putting the trans back in it could crack it. so be careful. make sure to bleed the system and put in clean fluid
Old Mar 15, 2009 | 07:47 PM
Clark Kent's Avatar
i just did the pilot bearing, i cant seem to get the throwout bearing off the slave though. i have the clutch alighnment tool, i just put it through and if it lines up i bolt it down, sorry its been 4 years since i last rebuilt my tranny and did the spec swap.
Old Mar 16, 2009 | 06:49 PM
Clark Kent's Avatar
ho do you know if the clutch has to be re-aligned? and how do you realign it? it looks as if the slave isnt compressing correctly? and making it hard for me to push the tranny in.
Old Mar 17, 2009 | 05:56 AM
Clark Kent's Avatar
Also, is there any way to compress the Slave Spring? it seems like it is right there and that damn spring is stopping it from going all the way in.
Old Mar 17, 2009 | 07:50 AM
Raven02TA's Avatar
if you are not able to get the input shaft all the way through the clutch and into the crank, its probably mis-aligned. (basically if you are having too many problems getting the trans in)
back the trans out. slowly loosen the bolts around the pressure plate to release the clutch (dont take the pressure plate off. just loosen it enough so the clutch can be moved around.) take the tool and re-align the clutch. while holding the clutch in position with the tool, start to re-tighten the bolts in a cross pattern. you should be ok
negative, the spring and the throw-out should compress themselves while you are installing the trans. however when you install the throw out it should be compressed after you get it to "click" on the slave
Old Mar 17, 2009 | 08:02 PM
Clark Kent's Avatar
Ok, ill do that tomorrow, btw thank you for all your help if it wasn't for you id be fuxored. should the spring be all the way back against the slave or be de-compressed?
Old Mar 17, 2009 | 08:30 PM
Raven02TA's Avatar
the throw out should not sit all the way against the slave. but should come to the end of it where it "clicks" on
Old Mar 17, 2009 | 08:59 PM
00PewterSS's Avatar
You do have to force in the trans against the slave spring. I'm in the middle of re-installing mine and I used longer bolts to get it started so you aren't fighting that spring while trying to start those bolts. I just read somewhere that someone just left the spring out altogether.
Old Mar 18, 2009 | 07:19 AM
Raven02TA's Avatar
thats just brilliant
Old Mar 18, 2009 | 09:00 AM
SPEC-01's Avatar
Guys...you really want to be careful if you are trying to pull the trans up to the motor using the bolts that secure it. Doing this can bend a disc and lead to issues of clutch release.
Old Mar 24, 2009 | 07:56 AM
Clark Kent's Avatar
**** it, i couldn't get that damn tranny all the way in, i took it to a shop and apparently i screwed up the pilot..? and broke the seal on teh slave. damnit, why can't this stuff just all go smoothly?
Old Mar 24, 2009 | 08:02 PM
00PewterSS's Avatar
Sucks man, I feel your pain. It isn't easy to get it well aligned and you really have to make sure it is before manhandling it or using bolts to force it the rest of the way. If it makes you feel any better I got mine back together and now 3rd is grinding.... grr.
Old Mar 24, 2009 | 09:49 PM
PewterScreaminMach's Avatar
Welcome to modding and working on cars, man.
