4th Gear issue
Old Mar 19, 2009 | 10:46 PM
the_merv's Avatar
Veteran: Air Force
Default 4th Gear issue
I got the Tranny in the Car finally.. since I got it in 4th Gear had been really notchy. Now after driving it around some today, as I put it into 4th and start to let the Clutch out it kicks the Shifter out of that gear and grinds. When I baby it into the Gear is when it kicks it out, if I'm holding it with some resistance it stays in.
Also, as I'm cruising if I push the Clutch in and move it out of 4th and try to easily put it back in, it grinds too.
I have a B&M Ripper Shifter with the Set Screws. I'm going to back off the one on the 4th Gear side a little bit and see if that helps.
Does this possibly sound like the 4th Gear Scyncro is out?
Old Mar 19, 2009 | 10:51 PM
getusum's Avatar
Yup.....My stock tranny did that to me in 3rd.....Sorry, but you'll need tha syncro....
Old Mar 19, 2009 | 10:55 PM
-LS1-'s Avatar
Sounds like a syncro issue to me...what was done to the trans when it was out? (since you said you finally got it back in)
Old Mar 19, 2009 | 10:57 PM
the_merv's Avatar
Veteran: Air Force
Ya that's what I figured..
I'll run it till it blows up I guess.
The Tranny is stock.. I just got done doing a T56 Swap.
Old Mar 20, 2009 | 08:49 AM
thesource's Avatar
Could be the syncro or it could be the pads on the fork are worn out . When you barely put it into 4th , there is not enough travel because the fork pads are worn out . If it does not grind at higher more forceful shifts , that probably what it is .
