Lets say i put new clutch disk in backwards?
Old Oct 20, 2003 | 10:59 PM
LSmokin1's Avatar
Default Lets say i put new clutch disk in backwards?
as the post says how would i know if i did put it in facing the wrong way. I have the clutch bleed says that mechanic that looked at it tonite and it still wont go into gear even if car has all 4 tires in the air. So he asked if i could have put the disk in wrong. what would happen if i ddi and how would i know i did before ripped the trans back out for 4th time.
Old Oct 20, 2003 | 11:47 PM
kp's Avatar
kp
Default Re: Lets say i put new clutch disk in backwards?
the clutch wont release at all most likely, you would not be able to put the car in gear if it were running.
If the disk is in backwards the part with the springs that sticks out further will be jammed up against the flywheel.
Your clutch may not be bled properly either.
Old Oct 21, 2003 | 08:06 PM
StangSlayerSS's Avatar
wow thats wierd!! i think i might have done the same thing was just gonna post that. im having the same problem. if you pull it out and flip it and it works let me know and if i get mine out 1st i'll let ya know.
Old Oct 22, 2003 | 06:33 PM
Mike K.'s Avatar
Mine would not go into gear intitially becase I had my master set to disengage/engage to early and I was not pushing on the pressure plate enough. If you have and adjustable master it may be worth checking this.
Old Oct 23, 2003 | 03:55 PM
Stick only's Avatar
If this is the case and it is backwards, be sure to check the disc for flatness. It could be bent and will not disengage at all if that happens...
Old Oct 23, 2003 | 06:40 PM
Scalpel's Avatar
Yep, my brother did the same thing. Car would not go into gear with the car on or off.
Old Oct 24, 2003 | 08:59 PM
Mike K.'s Avatar
I bet it is in backwards cause mine would go into gear with the car off just not when it was on. Kinda sucked cause I had to do a 3 point turn to get back to my driveway and I had to turn the car off each time to get it into gear.
LSmokin1 any updates yet on this?
