Odd tranny problem
Odd tranny problem
I have 94 v6 and whenever i let the clutch out trying to geter goin fast or spin the tires at a high rpm the back end thumps and doesnt sound to healthy and the stick jumps up and down. it doesnt stall but it doesnt sound healthy either. maybe the clutch slipping or a bearing or something?
checked into it. The mount he was talking about is between the crossmember and tranny and apparently you just pry back and forth between them and check for cracks. Ill check the torque arm to while shes up on stands
