crank freeze plug
Old Mar 23, 2009 | 09:43 PM
Rickyh93's Avatar
Default crank freeze plug
I think I knocked my freeze plug loose when I removed my pilot bearing. it looks like I hit it is some with the chisel I was using to get the old pilot bearing out. It looked fine but now that everything is back together I can see slight oil drip every now and then.
Any ideas how would I go about removing and installing this without knocking it into my oil pan.
Thanks for any help. I'm hoping to start tearing it all back apart again sometime this week.
Ricky
Old Mar 23, 2009 | 10:47 PM
Rickyh93's Avatar
I found the illustration in the repair manual. I know how far to set he new one in there now. can I just knock it in some on one side and pull out or should I try to screw aself tapping screw in and pull it out that way.
