transmission swap
I have:
-T56 trans.
-Clutch.
-Flywheel.
-Master cyl.
-Slave cyl.
-Pilot bearing.
-Shifter.
-Both rubber boots.
-T56 crossmember.
-Pedal assy.
You are going to have to drill a hole for the master cylinder. If my car was down there I would let you look at it to get a reference point on where to drill
Kyle, it would have been a lot better and easier to have a nother car sitting there beside it to look at. I just mounted the pedals and started drilling, and got a hole saw about the same size as the master cyl, It want too bad.
Thanks guys, keep the advice coming.
The bracket is completely different, but i will make it work, i have a torch and welder and some scrap metal...
