To GM Synchromesh It or Not?
#61
I've said in another thread I currently have Pennzoil Synchromesh in right now...it's been about 2 years but only around 2,000 miles. I did not notice any difference when I switched from DexIII to Synchromesh so sometime I'll probably switch back to DexIII but I'm not in a hurry to do so.
#62
Just like I posted in an adjacent thread, I put in RP Sychromax and hated every second of it. I live in WA, so it can get lower than 60 degrees here
Sychromax wouldn't let my car shift back into first unless I was at a stop. It gound in otherwise. It was much worse when cold though. I drained it and put in RP ATF and it shifts perfectly (it took 1-2k miles before the fluid worked it's way completely through the trans).
Overall, I'd say if you live in the southern states you'd be fine with Synchromesh, but if you live in a colder climate, I would recommend ATF....my .02
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#63
Not to play devils advocate, but some of best T56 builders that run amazing 6spd times and shift harder and faster than most of us will recommend just plain ol dexIII.
That said...I just changed my fluid from Pennzoil Syncro, to Castrol DexIII and I noticed things are alittle smoother than before. This isnt a great comparison, because I just recently installed the Tick master cylinder as well. So what Im going to do, is run the Dex for awhile. See how it goes. Then im going to pump in 4 new qts of Pennzoil again. Its the only way to tell if there is a difference. I dont mind spending alittle money on an experiment...so if its better, then cool Ill stick with the Pennzoil. If it gets notchy again, Ill just dump it and toss in some new Dex.
Haha there is nothing worse than trying to figure out the best product to use, then getting 8000 different opinions.
J.
J.
#64
Re-read summit's site, Recommended for all Tremec transmissions. a T-56 is made by Tremec.
ATF is designed for Automatic Transmissions, it needs detergents because there is wear and friction meterial that floats around and hopefully the filter catches it.
The only thing the T-56 has is 2 half dollar sized magnets. This transmission is all hard parts and does not need detergent. GM found it more cost effective filling 100,000+ units with the same fluid rather then having 2 different set ups.
Think about it.
Think about it.
#65
I believe the correct GM part# Is 88861800 for the manual transmission fluid. Which is actually just dexron 3. Now for bonus points....where can I pick that up for cheap?
The following users liked this post:
wannafbody (06-23-2020)
