Do I need a blowpproof bellhousing or will my stock one hold
Would like to know if anyone has had a clutch explode and penetrate a stock bell housing? I have been running a stock bellhousing for several years but have always wondered how it would hold up if my clutch came apart. I usually dont turn more then 7500rpms but would still like to know if anyone has had a clutch penetrate an oem housing.
Thanks,
..RJ..
Would also like to know the differences between a t56 housing and a regular sbc housing other then the extra bolt hole.
Thanks,
..RJ..
Yeah its not overly common for them to blow but when it happens its uber scary. If your drag racing often with high RPM dumps on sticky rubber then its wise to insure your legs ( heck maybe even your life? ) by installing one. If its a street car and you keep your clutch in good repair ( meaning good quality parts and dont run it to the death ) then its unlikely you will have a problem.
That said the worst flywheel explosion I ever saw was on the street years ago on a 1-2 shift behind a 455 poncho through a super T-10 running the stock flywheel and a hays clutch. The flywheel blew apart so damn far it was unreal. A chunk blew through the wall of a Church that was WAAAAAY down the street... Not to mention the car... and the road? It probably came out in China somewhere... Luckily the driver was completely untouched but barely... Scared the ***** out of me I tell you that much
At the shop that I work at here in texas I have seen the aftermath of two clutch explosions first hand. One was a stock LS1 camaro w/stock clutch doing a burnout when the clutch let go. It destroyed the bellhousing and ripped a chunk off the engine block where the trans bolts up. So this guy had to pay for his engine block to be swapped out.
The next one was an 2001 vette w/ a 402 stroker and spray w/ a spec 3+ clutch. At the 1/8 mile the pressure plate exploded and it went through the windsheild, fender, and longtube headers. And to add insult to injury it also cut through the fuel lines which caused the fuel to ignite once it touched the headers and caught the vette on fire burning the hood, wiring harness, brake booster and everything else under the hood which totaled out the car. Thankfully the guy still has his legs.
IMO this is a must have item for safety reasons, just my $0.02
