TKO600 problem???
TKO600 problem???
Hey guys, I have a L92 that I'm swapping in a S14. I order a TKO600 with a Quicktime bellhousing. I have an Exedy twin plate clutch with a LS1 slave cylinder.
My problem is the slave don't fit on the TKO600, the shaft is too big for the slave. The spline have the good dimension but after the spline is bigger.
Can someone can help me asap please!
Thanks!
Kevin..
Thanks!
Kevin..
Thanks!
Kevin..
Thanks!
Kevin..
As you found out, you can't use an LS1 slave with a TKO. Check out my build thread. Link in sig. I installed a Richmond 6spd behind my L92. The TKO will fit the same way. There is a ton of detail in my write up.
Andrew
