clutch problem
Old Mar 31, 2009 | 11:03 PM
boostinsidewayz's Avatar
Default clutch problem
i just bought a 2000 formula and i'm having some problems with the clutch.
i read the drill mod sticky and the shim sticky and i think the shim problem might be what i have, but i'd like to get some opinions.
when i release the clutch in 1st gear it takes about a second to full engage. the clutch also engages about 1.5-2'' from the top of the pedal. the clutch will slip if i'm in a higher gear and try to give it gas. its a spec 3 clutch with about 10k on it(according to previous owner)
is my clutch shot? is there a way to adjust where the pedal engages without buying an adjustable master cylinder?
Old Apr 3, 2009 | 08:14 AM
Silver98Formula79's Avatar
It sounds like your clutch...you would need an adj master to play with the pedal engagement. I had a spec 3 it seem to last me about 15kmi with only 10-15 track passes.
