Slave quick disconnect
Old Oct 23, 2003 | 12:37 PM
sprayed93lx's Avatar
Default Slave quick disconnect
Whats the easiet way to take it off? I heard fuel line tools and everything else. But im not having any luck.
Old Oct 24, 2003 | 08:20 AM
Jason99T/A's Avatar
I can shift faster than you.
There is a tool that Snap-on, Matco, etc. sell. It is a Ford disconnect tool, but will work just fine on the LS1s. If you don't have access to one of these, just use two small screwdrivers and push in on the white collar. Once you have it pushed in far enough, you should be able to pull the line out.
Old Oct 24, 2003 | 11:24 AM
93LS1RX7's Avatar
what size oring goes on the line where it mates to the slave? inside diameter and outside and size please
Old Mar 19, 2005 | 10:56 AM
ls1mx5's Avatar
bump
does anyone have this info?
thanks!
karl
Old Mar 21, 2005 | 04:09 AM
Mike K.'s Avatar
2 small screwdrivers works really good, just turn them sideways and push on both sides like you are using 2 small plates.
Old Mar 21, 2005 | 07:34 AM
hourang's Avatar
get a fuel line disconnect tool set, its like a couple bucks at any parts store and was easy as pie. had no luck with 2 screw drivers.
Old Mar 21, 2005 | 09:40 AM
NOBR8KSS's Avatar
I found that an open end wrench works really well...just choose the size that fits over the connector and press in...works like a charm.
Old Mar 22, 2005 | 12:11 AM
Mike K.'s Avatar
damn thats a good idea, even easier than screwdrivers.
Old Mar 22, 2005 | 10:15 AM
demonspeed's Avatar
It's not mine! woo hoo!
That would definitly be the easiest way. I too used the two screw driver method. It's a breeze, so don't waste money on any special tools (though the fuel line disconnect stuff isn't pricey and you'll probably use them for other stuff in the future).
Old Mar 22, 2005 | 10:23 AM
hourang's Avatar
ive used my fuel line disconnect tools so many times i can even count. fuel lines, a/c lines, slave, etc. very handy to have around.
Old Mar 22, 2005 | 11:12 AM
Stryker's Avatar
screw drivers does it in a second so why even make a deal out of this? just push it in a lil bit then pull on the hose and it should come right out..
