Hard to get T56 into reverse??
Im not talking about its hard to get past the detent, im talking about after you bring it all the way to the right, past the detent, then push it straight up. It just dont want to go.
Your issue with 3rd could be a worn or cracked blocker?
Yeah I just did a search and found this article, I can't believe how many people have this problem. I just had this happen to me but I've always had a m6 car. One day I go to back out of my drive way and can't put it into reverse. I have to use my left arm (my a lefty as well) and then I have enough power to throw it into reverse.It would make sense that the reverse lockout is the reason. I just don't know how this happened, and how I go about fixing it. I really don't want to buy a brand new tranny because I plan to do an LS swap eventually. I'll check the fuses though.
The stick will resist going into the reverse position, but I would be able to get it in, but when I go to actually back out, the transmission will make a grind noise and car wont move. I'll have to move the stick out of reverse, then back in again, this 2nd time with no problems.
If its going to give me a hard time, its like neeshSS's post, it will be the 1st time starting up (cold) and backing out of the driveway. After that, I dont notice the problem all day/night long.
I had the dealer look at it 2-3 times while under warranty, but we couldnt make it happen at the shop, go figure.
2 years ago now I swapped out the stock clutch for a trex, clutch is great and the 'reverse issue' still happens occassionally. I have no idea why. Maybe its that "reverse blocker ring wave washer" - but I'm not into tearing down the trans to find out.
The reverse inhibit solenoid is a safety feature which prevents an inadvertent shift into reverse at speeds above 5 km/h (3 mph). The system consist of the following components:
• The powertrain control module (PCM).
• The reverse inhibit solenoid.
With the ignition ON, battery voltage is supplied directly to the reverse inhibit solenoid. At forward speeds above 5 km/h (3 mph) the PCM opens the control circuit of the reverse inhibit solenoid. This de-energizes the solenoid and mechanically blocks the shift lever from going into the REVERSE position.
